| | | Forums66 Topics128,196 Posts1,057,392 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 40 | I have a 49 3800 flatbed that I am about to replace the entire rear axle with a more modern axle. My question is what are the axle widths of a 3/4 ton 67-72 truck and the axle widths out of a 73-87 model? My truck is a flatbed and I don't care to much if these axles are a bit wider. I just don't want and axle that is a foot wider. The 73-87 models will be the easiest to come by. | | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | I don't know what numbers you are looking for but... I have a 1984 c30 from the back of the brake drum to the back of the brake drum is 55 in cl of the spring mount is 40 " cl of the axle to yoke is 18 " looking at my 1959 3600 I have 52 " brake to brake 41.5" cl of spring to cl. 18" cl of axle to yoke. This is a dual wheel rear so outside of wheel to outside is 90" if that will fit under your flatbed. I looked at 3/4 ton rears awhile ago trying for a better gear they were close but I had concerns about driveshaft length/universil joint and weather the brakes would work well. If you need a specific measurement let me know. | | | | | Joined: Oct 2006 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 40 | The measurement that I'm looking for is the overall axle width where the wheels bolt on(flange to flange). I plan on bolting my original wheels back on. | | | | | Joined: Oct 2006 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 40 | If your truck is a dually, I think the axle width will be different from a normal 3/4 ton. | | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | yes the housing to the brake plates is the same but the drums are much wider. i would try a junk yard. | | |
