9 members (TUTS 59, Millenimech, cmayna, Hanks custodian, Otto Skorzeny, Oswald, Cosmo, Bill Hanlon, gswbbc), 89 guests, and 3 robots.
Topics128,042
Posts1,055,522
Members48,424
#785974 10/04/2011 6:29 AM
My sending unit no longer works. Should I buy used or new? What would you recommend and from who? 1960 Suburban the tanks in the rear with the spare tire unit below. If this doesn't belong here let me know where so I can relist in the proper place. Thanks
Kevin G #785984 10/04/2011 11:51 AM
i have a spare old unit, did you check the wiring and ground first? i can check to se iff the resistance changes on mine. not much available for burbs. you would have to use your old pieces and install my resistance unit on your because my float piece is shot.
DThela #786043 10/04/2011 4:56 PM
check to see if the float has a hole in it. if you need a sending unit i have one for a 65 suburban minus the float
k10 Offline
http://www.rockvalleyantiqueautoparts.com/catalog.htm
Rock Valley is an excellent source for universal senders for various ohm ratings. And also for gas tanks. Nice little company. I have a 0-30 ohm from them for my 6 volt truck and it's working great.
k10 Offline
k10 #786543 10/06/2011 7:03 AM
I believe I have enough info. Thanks to all that responded.
