5 members (2-Ton, 1955 1 Series, pdlightning, TooMany2count, Shade Baby), 154 guests, and 3 robots.
Topics128,079
Posts1,056,286
Members48,441
#785883 10/04/2011 1:54 AM
I purchased a SPECTRA PREMIUM GM55A Fuel Tank for my 54 Chevy 3100 ... I received it last Friday... I was going to install it today... I looked inside the tank and saw some water in the bottom of the tank... On the bottom seam there is some flash rust forming... Do I need to be concerned ?
Has any one purchased one of these tanks ? Are they supposed to coated and sealed on the inside from the factory ?
I did research and found that SPECTRA PREMIUM Fuel Tanks to be the best and being true to the original tanks...
Thanks in advance...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
I got one in 2 weeks ago. GM55A ordered through rock auto.
I looked inside and saw brown color. I my case is was an oil coating most likely from the production process.
it was blocking the outlet.
...pic...
...pic...
...pic...
..inside tank pic...
I just installed a pipe plug in the outlet and poured some solvent in the tank and swashed it around. Cleared the outlet and made sure there was no loose material in the tank.
I think the tanks are tested with air.
Update: Sent tank back and received a new replacement today that has no signs of flash rusting... Had no problem with Rockauto in exchanging for a replacement...
Getting closer to be on the road again after 28 years...
