6 members (tclederman, gswbbc, TIM ZINDLER, HandyAndy, Stovebolt48, rfs56trk), 94 guests, and 2 robots.
Topics128,040
Posts1,055,478
Members48,424
Page 2 of 2 1 2
Check your private messages.
Figured that starter out yet?
nope ! but I discovered another bizzare senario,with the spark plugs out it turns over really fast , as you would expect , but with them in it turns over slower and this is when the lever gets stuck to the button,however whithout the plugs everything releases as it should ??????????????????
obviously there's lots more current draw - how long are you cranking it before it sticks? [with the plugs in]
about 5 sec. max.
I wish I were close enough to come by. Surely someone is close enough to go look with you and see what is going on.
But it's a longgggggg drive from Ranger, TX to Toledo, Ohio.
Still curious about this starter problem. Did you get it working? If so, what did you find wrong? Inquiring minds want to know. smile
unbelieveably no , ,I wish someone would of had the answer , i'ts so close to starting ? I won't make the same mistake twice , quit now and pull it for an engine swap 350 -350 ' and have adependable more powerful set up that is ease to fix and get parts for , if you know any one wanting this motor or where i can post it let me know , thanks for all your help and interest .
Well, its hard to hammer a nail over the internet.
Why not try another starter?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
55 redstove,
I know you must be extremely frustrated by now.
It seems like it has to be one of two things. Either you have current to the starter button and it is shorting/grounding to the lever, or you somehow have current to the arm and it is shorting/grounding to the button.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Take a volt meter and put one lead on the lever that pushes the button, and put the other lead on the button and see what you have.
Put a rubber cap over the button and see if it starts without the lever sticking/ welding to the button.
No one close enough to Ohio to go help him? I would if I wasn't so blooming far away. Wonder what a round trip plane ticket cost? I would love to see what it going on.
Page 2 of 2 1 2
