| | | Forums66 Topics128,041 Posts1,055,487 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | I'm looking for a 7 wire turn signal switch like an old Signal Stat kits. I've currently got a 4 wire Signal Stat but want to be able to share turn signals & brake lights.
I just purchased a 7 wire switch from Classic. These things are garbage: chrome plated plastic, a hose clamp to mount on the column, it can't get much worse than this. There is no way I'm putting this on my truck.
Does anyone out there make a good quality metal 7 wire switch? Thanks.
It never costs more to ask and it never costs more to think big.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I would go with a stock GM switch. Second choice would be a reproduction of the stock switch. I saw them in Classic's catalog but I have no idea about the quality. | | | | | Joined: Nov 2011 Posts: 3 New Guy | | New Guy Joined: Nov 2011 Posts: 3 | You can still buy the signal stat 900 7 wire. Just installed on my 53. Nice retro look. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well that's half the answer Dan, now where did you buy that "Signal Stat 900 7wire" new? The only thing that I can find still made by Signal Stat in their signal line up is this: http://www.truck-lite.com/wcsstore/tl/resources/images/en_US/PDF/2011/03Signal.pdfDenny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just went out and dug out my seven wire signal unit. It came with the truck in '05 when I bought it. The previous owner had ordered a box full of stuff from Chevy Duty but never didn't have the truck long enough to put any of it on the truck. Yes the unit clamps on to the mast jacket, but that was the way that all of the aftermarket units were attached, nothing unusual there. And the unit is not plastic it's a chrome plated die-casting. Actually its a pretty solid looking unit and looks pretty much just like the original Signal Stat units. Maybe since ya'll made me get it out, I'll dust it off and install it this winter.
Denny G
| | | | | Joined: Sep 2011 Posts: 15 New Guy | | New Guy Joined: Sep 2011 Posts: 15 | Just bought one new from NAPA. Less than $60.00. Looks good, hope to finish the install this weekend. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Just bought one new from NAPA. Less than $60.00. Looks good, hope to finish the install this weekend. do you have a NAPA part number for that switch? | | |
