1 members (Hotrod Lincoln),
327
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | I know that these trucks have a resistor in the wiring harness, but in looking at the factory build/books and assembly manuals...I just cant seem to locate it. Any help would be appreciated. | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | What year truck? The ceramic-shielded resistor was only used for a short time, then they went to a nickel-chrome alloy resistance wire from the ignition switch to the coil. "bypass" voltage is provided either from a second (copper) wire from the switch to the coil called "Ign 2" which is hot with the key in the start position, or by a bypass wire from a small terminal at the side of the stomp-start switch to the coil (+) terminal. Jerry
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The resistor is in the wire itself, it's the cloth covered one. | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | its a 63 1/2 ton w/factory mechanical guages | | |
