7 members (baldeagle, Hotrod Lincoln, Bill Hanlon, fonz8261, greenie-reddy, 2 invisible), 367 guests, and 4 robots.
Topics128,162
Posts1,057,068
Members48,463
I know that these trucks have a resistor in the wiring harness, but in looking at the factory build/books and assembly manuals...I just cant seem to locate it. Any help would be appreciated.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
H Online: Content
What year truck? The ceramic-shielded resistor was only used for a short time, then they went to a nickel-chrome alloy resistance wire from the ignition switch to the coil. "bypass" voltage is provided either from a second (copper) wire from the switch to the coil called "Ign 2" which is hot with the key in the start position, or by a bypass wire from a small terminal at the side of the stomp-start switch to the coil (+) terminal.
The resistor is in the wire itself, it's the cloth covered one.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
its a 63 1/2 ton w/factory mechanical guages
