7 members (Otto Skorzeny, J Lucas, klhansen, Tronman, electors, 78buckshot, 1 invisible),
106
Mod | | | Forums66 Topics128,042 Posts1,055,497 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 20 New Guy | | New Guy Joined: Jul 2010 Posts: 20 | is there a positive and negative post on gas guage or are they interchangable? Does the gas tank sender unit need to be grounded to chasis or does it ground via tank? RS
Blue51
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you are referring to a Chevrolet truck rather than a GMC truck:
There is an input post on the fuel gauge for the power-in (positive lead) lead. The other post goes to the sender.
Yes, it matters which post you put the power to - if you choose the wrong post, you'll fry the gauge.
There might be a warning tag around the input post on the fuel gauge.
The sender grounds via the tank (but, some people run a ground lead from a sender attachment bolt to a clean ground-point).
