| | | Forums66 Topics128,154 Posts1,056,851 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 46 | I've been told that I have a 1954 235 engine and would like to swap with a newer 5 speed overdrive floor manual shift tranny. A fellow burber told me that a Chevy S10 would work with an adapter. Question where would I find this adaptor and will new transmission fit in same hole of floor transmission coverplate? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Shouldn't need an adapter, the S10 T5 will bolt right up. I'm not sure about the shifter, but I beleive it will be ok, or at least close.
Bill Burmeister | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The biggest problem on the 54 on back you have to put a open drive shsft 3rd member in & weld up the pivots where the rear axle attaches to the springs. Read up on it. What ever you have to do the results are rewarding. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2011 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 46 | Well, this engine is a 54 but I have a 49 panel. I don't know if this helps on answers. I appreciate all the answers so far. Thank you all! | | |
