0 members (),
155
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 18 New Guy | | New Guy Joined: Sep 2008 Posts: 18 | I am somewhat new to the stovebolt area and just finished my first 55 chevy 2nd series....now I'm hooked. My wife saw a truck today for sale and I spoke to the owner. He said its an all original 54 5 window long bed 3/4 ton (3600) with a 265 engine. I didn't think the 265 came until 1955. Could he be mistaking his 54 for a 55? What would be the easiest way to tell the two apart? I'm assuming if it is in fact a 54 with a 265 then the engine was added later. Thanks guys. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The 265 is unique in the way that it actually fits into an AD truck. It had no side motor mounts so it front mounted and it's bellhousing had the rear motor mounts on it both of which are like the inline six but NOT interchangable. The left hand exhaust manifold has a dip in just the right place to clear the steering box and the exhaust outlet is towards the front which also clears the gearbox. When done right it does look like a factory install but no V8 was offered in the AD style truck. The 265 was offered from 55-57 in trucks but just 55 & 56 in cars. If the oil filter is in a canister mounted to the T-stat housing it's a 55.
Evan
| | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | The 265 was also offered in 57 cars but few were sold. | | | | | Joined: Sep 2008 Posts: 18 New Guy | | New Guy Joined: Sep 2008 Posts: 18 | thanks guys. When I went out and saw the truck, it was actually a 235. Too much rust for me however. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | There was nevere a 54 or 55 1st that left the factory with a 265. If you search posts from wdoftexas, I think you will find conflicting information on the fit into an AD truck. You would have to show me some pretty solid proof to make me doubt the comments he made earlier. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 265 is unique in the way that it actually fits into an AD truck. It had no side motor mounts so it front mounted and it's bellhousing had the rear motor mounts on it both of which are like the inline six but NOT interchangable. The left hand exhaust manifold has a dip in just the right place to clear the steering box and the exhaust outlet is towards the front which also clears the gearbox. When done right it does look like a factory install but no V8 was offered in the AD style truck. The 265 was offered from 55-57 in trucks but just 55 & 56 in cars. If the oil filter is in a canister mounted to the T-stat housing it's a 55. All the componets listed are separate parts that can be fit to any smallblock Chevy. Also, the provisions for the front mounts are present on all smallblock Chevy engines, thouhg some blocks my not have the holes tapped.
Bill Burmeister | | |
