| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78340 06/03/2007 2:50 AM | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I'm thinking of going to dual 1brls on my 235. What other 1brl carbs have the 2 15/16" center to center at the mounting holes. I would like to have some other choices besides the Rochester. Thanks | | |
#78341 06/03/2007 3:16 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I like Holley model 1904s myself. The Carter YF is another good choice, but caution needs to be exersized as it's real easy to end up with a ford unit that's jettet WAY to rich for a Chevy.
Bill Burmeister | | |
#78342 06/03/2007 1:10 PM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Use the search function for a thread dated 18 Feb 2006 entitled "What Carbs are Best".
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
