3 members (klhansen, ndkid275, Otto Skorzeny), 119 guests, and 1 robot.
Topics128,151
Posts1,056,994
Members48,460
I'm trying to locate a set of the inner fenders (wheel tubs etc) for a 58-59 shortbed fleetside. As far as I can tell no one makes a reproduction one, are there any other years of trucks that match up to the same mounting holes?
Thanks!
Alden
Hey Alden saw no one has posted yet for this but I'm in the same dilemma. Ive found that dimension wise the 1960 fleetside tubs are the same but the flanges do not match up with the bed strips between the wood. I'm thinking about getting some 60 tubs and buying the flange repair kit from classic parts. Well I was just searching for the flange repair kit and came across this... Inner Wheel Tub So scratch everything I said unless you have some old 60as tubs sitting around.haha.. Josh
I never let the truth get in the way of a good yarn..
Unfortunately these are repo mid-sixties tubs that will work but aren't quite the same (shape is a little different and flanges are different). I looked hard for some used originals - bought four to find two that were good w/o replacing flanges. I still have the other two but they have some dents and at least one needs flanges. Good luck!
gobolt
