| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78320 06/01/2007 6:22 PM | Joined: Sep 2004 Posts: 3 New Guy | | New Guy Joined: Sep 2004 Posts: 3 | I have a 53 Chevy ¾ ton that I’m working on the two piece driveshaft. I am having trouble finding the oil seal that goes in the end of the tube to keep oil from leaking out near the support bearing. If you are standing on the driver’s side and look at where the first shaft joins the transmission, then follow the tube back to the support bearing. Just before the support bearing inside the tube there’s an oil seal (National 1-34) is what mine had. I can't seem to find anyone that has this seal.
Has anyone replaced the bronze bushing at the tranny end of the tube? Can't seem to find that one also. | | |
#78321 06/02/2007 2:43 AM | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | I beleive that I have a new bushing and maybe a seal. | | |
#78322 06/04/2007 3:05 PM | Joined: Sep 2004 Posts: 3 New Guy | | New Guy Joined: Sep 2004 Posts: 3 | Thanks, But I think I have it under control. I was able to find the seal from a local bearing supply company and I will need a custom bushing because of the wear on the mating part. I have order a standard bushing and will turn it to fit. | | |
#78323 06/05/2007 6:57 AM | Joined: Feb 2002 Posts: 61 Member | | Member Joined: Feb 2002 Posts: 61 | How much wear on the mating part?
1948 Dodge 2 ton 1950 GMC 1 1/2 ton 1952 GMC 3/4 ton
#78324 06/05/2007 2:13 PM | Joined: Sep 2004 Posts: 3 New Guy | | New Guy Joined: Sep 2004 Posts: 3 | I had 0.004" wear on the yoke, so I made a fixture and ground the OD surface on the lathe. I will bore the bronze bushing to fit with a RC5 running fit for oil. | | |
