1 members (78buckshot),
176
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i am about to assemble my '56 bench seat since it has been re-covered. THere does not seem to be holes through the upholstery on the bottom half to accept the the thru-bolts for the arms from the back. do these bolt thru the upholstery or under it? Do I punch a hole or cut a slit, or what? anyone have a picture? | | | | | Joined: Oct 2008 Posts: 22 New Guy | | New Guy Joined: Oct 2008 Posts: 22 | You need to cut a nice round hole a little bit bigger then the bolt hole in the upholstery. You need to put a plastic washer between seat bottom over the upholstery and the arms from back rest so it doesn't bind up when you fold seat back forwards. Ask your upholstery shop for them. It could rip and ruin your seat upholstery if you don't install them. . If you have any other questions ask I have been doing upholstery for over 30 years. Tom | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | that's awesome, Tom. thanks. how big is this washer? actually, can you sell me some? | | |
