| | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | The shop next to me is working on a 59 apache which has a booster and MC mounted on the firewall. I overheard a mechanic complaining about the amount of flex in the firewall when the brakes are applied resulting in the MC assembly moving a good 1"+ upward.
What year did General Motors start mounting the MC on the firewall and what is a good remedy to fix such a flex?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | I was reading in a mag about this. They make a braket that when you cut out the old dash brase you mount in the new one and it will stop the movment. If you were just to put in the Master cylinder and not the brase then ya it will move. See in this photo From Classicparts it has the brase on the back http://www.classicparts.com/images/71-925B.JPG | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 1960 was the first year for the firewall mounted master cylinder in trucks. As GranpasTruck mentioned, there needs to be proper bracing to prevent the flex.
Bill Burmeister | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Thanks, I'm going to go over and sneak under the dash to see if there is a brace.
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | I have one of those set-ups in my '53 and it's solid as a rock. No flex at all. Bolts to the firewall and to the dash.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: May 2010 Posts: 85 New Guy | | New Guy Joined: May 2010 Posts: 85 | I have a 52 chevy 3100. I mounted the booster on the firewall. Got the kit from performance online. The mounting bracket incorporates the support for the steering column. I have no flex issues. Master is solid.
Do something! Even if it's wrong!
