2 members (Otto Skorzeny, 1 invisible), 136 guests, and 1 robot.
Topics128,109
Posts1,056,266
Members48,439
The shop next to me is working on a 59 apache which has a booster and MC mounted on the firewall. I overheard a mechanic complaining about the amount of flex in the firewall when the brakes are applied resulting in the MC assembly moving a good 1"+ upward.
What year did General Motors start mounting the MC on the firewall and what is a good remedy to fix such a flex?
Craig
I was reading in a mag about this. They make a braket that when you cut out the old dash brase you mount in the new one and it will stop the movment. If you were just to put in the Master cylinder and not the brase then ya it will move.
See in this photo From Classicparts it has the brase on the back
http://www.classicparts.com/images/71-925B.JPG
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
1960 was the first year for the firewall mounted master cylinder in trucks.
As GranpasTruck mentioned, there needs to be proper bracing to prevent the flex.
Bill Burmeister
Thanks, I'm going to go over and sneak under the dash to see if there is a brace.
Craig
I have one of those set-ups in my '53 and it's solid as a rock. No flex at all. Bolts to the firewall and to the dash.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
I have a 52 chevy 3100. I mounted the booster on the firewall. Got the kit from performance online. The mounting bracket incorporates the support for the steering column. I have no flex issues. Master is solid.
Do something! Even if it's wrong!
