Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (78buckshot), 176 guests, and 3 robots.
Topics128,274
Posts1,058,433
Members48,490
#782796 09/22/2011 1:18 PM
i am about to assemble my '56 bench seat since it has been re-covered. THere does not seem to be holes through the upholstery on the bottom half to accept the the thru-bolts for the arms from the back. do these bolt thru the upholstery or under it? Do I punch a hole or cut a slit, or what? anyone have a picture?
You need to cut a nice round hole a little bit bigger then the bolt hole in the upholstery. You need to put a plastic washer between seat bottom over the upholstery and the arms from back rest so it doesn't bind up when you fold seat back forwards. Ask your upholstery shop for them. It could rip and ruin your seat upholstery if you don't install them. . If you have any other questions ask I have been doing upholstery for over 30 years. Tom
that's awesome, Tom. thanks. how big is this washer? actually, can you sell me some?
Moderated by  ndkid275, Phak1
