0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
Seeing I have a cracked lower corner on my side window I thought I's make a pattern and get a local glass shop to cut me out a couple new windows... you know keep it local and all that.
On line they're 30 apiece incl. shipping more or less. No frame just the glass.
One local shop say's 60 bucks apiece and the cheap one says $45 ea.
So much for supporting the local guys... ohwell
Give me ambiguity
or give me something else
You should install new seals or the excess travel may break the new glass, maybe why the old one broke.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
Already have everything.
Give me ambiguity
There have been experiences here on Stovebolt where replacement windows purchased from an aftermarketer don't quite fit. At least with your local shops any adjustments will be easy to make.
Drew
Its just glass, if its to big the local shop is just gonna do what I'll do, put the sander to it and grind it down a bit more.
I guess I'm just an old school CASO
(Cheap [censored] stovebolt/studebaker owner)
Give me ambiguity
