1 members (stlcardinalsguy),
115
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 30 New Guy | | New Guy Joined: Dec 2006 Posts: 30 | Does the gas/fuel reading on guage go to the Empty side or stay at the actual level that's in the tank itself after key/ignition is shut off? Pre-thanks in order...
Last edited by FishSteelhead; 09/18/2011 8:00 AM. Reason: better breakdown of question...
"There's no head like Steelhead" | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | is the sending unit 30 or 90 ohms do you know. sometimes it is a ground problem ron. a lot of the replacements are 90 ohms which was 66 and most prior to that were 30 ohms sending units | | | | | Joined: Dec 2006 Posts: 30 New Guy | | New Guy Joined: Dec 2006 Posts: 30 | Pad, I thank ya' for the come back however, am just wanting to know where the stock gas gauge normally reads after ignition key is off ie., goes to empty or stays at what the actual gas level is at...
"There's no head like Steelhead" | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | think that it goes back to empty ron | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Neither my '65 nor my '66 have a memory. When the power is off they drop to below "E". Both are stock, one has guages and the other idiot lights.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | My 63 drops to empty when the ignition is off | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | My '65 drops, but not necessarily to E.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | |
