6 members (Pete O, moparguy, Gdads51, Shaffer's1950, ronsway, Robert Crandall), 79 guests, and 2 robots.
Topics128,150
Posts1,056,985
Members48,460
the valve cover on my 46 is aluminum I believe with the following stamped on it....
C.A.W.
4851 W.Hayward PL
Denver Colo
Pat Pend.
Any ideas as to what this means? It doesn't look like a standard valve cover. Thanks
Cast Aluminum Works
424x4
Thanks for the info on the valve cover. Why this type of cover and not the standard cover that I see in all the other pictures. Could it be because it is a "black out". The serial # on the truck is 3CKo9 - 1206. As Always....Thanks!
Jed Offline
Mouchy,
It would be my guess that someone at some point changed the cover, rather than because your truck is a "black-out" model.
Living in the Denver area, I got curious, so I did a reverse search on the address you provided above.
Seems they must have torn down the place long ago, because that address is listed as being a residence now.
Got any pictures of the cover?
yes and thanks for the research. I will see if I can post it. Don't know how yet.
