| | | Forums66 Topics128,088 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 6 New Guy | | New Guy Joined: Sep 2011 Posts: 6 | Can anyone tell me what kind of transmission came in a 58 GMC 2 ton truck and how hard is it to mount to a later model V8 out of a car? All I know is that the truck has a manual trans in it. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If it is indeed a 2 ton such as a 350 series it would have come with a SM420 4 speed. The engine compartment is built to accommodate a v8 because a Pontiac v8 was an option. Most any v8 will fit. A Chevy with a GM truck clutch housing will bolt to the transmission and front motor mounts are not much of a challenge to modity. | | | | | Joined: Sep 2011 Posts: 6 New Guy | | New Guy Joined: Sep 2011 Posts: 6 | Well a pontiac 400 is what is going in it and it is a 350 series but it had a 5spd trans in it with R and 1st on the far right. Any ideas. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If it is a 5 speed with reverse away and up with 1st away and toward the seat it is a Clark. If 1st is toward you and up, it is a New Process. A Clark 205 or a New Process 540 were both options. Was it born with a 6 or a v8? If it was born with a v8 the clutch housing will bolt to a Pontiac. | | | | | Joined: Sep 2011 Posts: 6 New Guy | | New Guy Joined: Sep 2011 Posts: 6 | 1st is away and toward the seat. I'm not sure what the factory engine was. There is a straight 6 in it now. All the tags are gone under the hood. Is there a way to find out 4 sure if that's the factory engine? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | That would make it a Clark. They were popular for use in soft ground because you could rock the vehicle back and forth to get out of a mud hole. It doesn't make much difference what the truck had in it, but it would certainly be nice to start out with the correct clutch housing and front engine mount to install a Pontiac. Does it have an ID tag on the door jamb. That will tell you if it was born with a 6 or V8. | | |
