6 members (Gray_Ghost, Guitplayer, Joe H, Youngin' Tut 59, Wally / Montana, fonz8261), 163 guests, and 1 robot.
Topics128,192
Posts1,057,351
Members48,469
Does the gas/fuel reading on guage go to the Empty side or stay at the actual level that's in the tank itself after key/ignition is shut off? Pre-thanks in order...
Last edited by FishSteelhead; 09/18/2011 8:00 AM. Reason: better breakdown of question...
"There's no head like Steelhead" wink
is the sending unit 30 or 90 ohms do you know. sometimes it is a ground problem
ron.
a lot of the replacements are 90 ohms which was 66 and most prior to that were 30 ohms sending units
Pad,
I thank ya' for the come back however, am just wanting to know where the stock gas gauge normally reads after ignition key is off ie., goes to empty or stays at what the actual gas level is at...
think that it goes back to empty
ron
Neither my '65 nor my '66 have a memory. When the power is off they drop to below "E". Both are stock, one has guages and the other idiot lights.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
My 63 drops to empty when the ignition is off
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
My '65 drops, but not necessarily to E.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
