3 members (TexasJim50, 1955 1 Series, Rexville48), 103 guests, and 3 robots.
Topics128,141
Posts1,056,488
Members48,441
I have a 65 chevy c-10 1/2 ton with three speed on column
THe pin that holds the shift lever arm to the lever housing at the base of the steering wheel always wants to work out after shifting gears around
How do i keep the pin in and not falling out as I use the shift lever arm
Thanks for the help
Ken
Most of the pins I'm familiar with have a short knurled section at the top, which is supposed to swedge into the diecast shift collar. Once the collar wears enough for the pin to get loose, it's almost impossible to keep it secured. I'd suggest a drop or two of red LocTite on the knurl, or JB weld, if it's really worn at the knurled area. Just don't stick the shifter to the pin, as it needs to pivot there.
