| | | Forums66 Topics128,131 Posts1,056,369 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78158 05/29/2007 3:24 AM | Joined: Apr 2007 Posts: 44 Member | | Member Joined: Apr 2007 Posts: 44 | I have a 65 chevy c-10 1/2 ton with three speed on column THe pin that holds the shift lever arm to the lever housing at the base of the steering wheel always wants to work out after shifting gears around How do i keep the pin in and not falling out as I use the shift lever arm Thanks for the help Ken | | |
#78159 05/29/2007 4:07 PM | Joined: Feb 2004 Posts: 29,813 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,813 | Most of the pins I'm familiar with have a short knurled section at the top, which is supposed to swedge into the diecast shift collar. Once the collar wears enough for the pin to get loose, it's almost impossible to keep it secured. I'd suggest a drop or two of red LocTite on the knurl, or JB weld, if it's really worn at the knurled area. Just don't stick the shifter to the pin, as it needs to pivot there. Jerry
