1 members (2-Ton), 167 guests, and 3 robots.
Topics128,088
Posts1,056,114
Members48,434
#779722 09/11/2011 2:34 AM
I'm having a hard time getting the raybestos part numbers for the front and rear wheel cylinders on my 59 3800, the parts books at the local flaps only go back to the early 60s I can get them at a fair price if i can just get a p/n I need them for the front and rear shoes too if anybodys got that info. Thanks everybody
3B Offline
Hy panman, the Raybestos numbers are
front wheel cylinders WC18009
rear wheel cylinders WC18010
front brake shoes 123PG
rear brake shoes 109PG
hope that helps.
thanks 3B that's a good start, i hope i can find that stuff .
3B Offline
Hy panman, Rock Auto has all the parts, prices are in Canadian dollars (forgot to select U.S. dollars, so prices will be a bit more)
123PG $23.71
109PG $70.53
WC18009 $20.92
WC18010 $45.73 hope that helps.
hey 3b i got my shoes from Napa today, they had them on the shelf! i couldn't believe that, i ordered the rear wheel cylinders from Kanter in new jersey, they had them oem, on the shelf too $40.00, What i'm having real trouble with now is some kind of spring set, and getting the shoe adjusters unstuck. I think i can get the one adjuster that is still stuck apart, but i would really like to get some new springs, 3B do you have the part number for a spring kit?? and new adjusters? man that would be kool but man i really want to thank you for those part numbers it helped me a bunch
3B Offline
Hy Panman, this info was a little tricky to find, and I can't be 100% sure of it, I think the rear spring kit should be Raybestos p/n H9206, I think the front spring kit should be Raybestos p/n H7019, I'll keep looking for the adjuster assemblies. Do you need both front and rear adjusters?
3B Offline
Hy panman, rear adjusters are Raybestos p/n H1508, front adjusters are Raybestos p/n H1500-2, you could use p/n H1500 as well, I don't see a difference in the pic's but H1500-2 is cheaper???, hope that helps, I've got a headache now, so off the confusilator for me.
Riding in the Passing Lane
the napa part # on the springs for 12 in. brakes are 80301 for the return springs. 80412 for the hold down kit. That is axle sets & the same for front & rear.The adj. screw spring is 80518. It doesnt show the adj. screw. Usually some heat will free it up.
1972 Chevy c10 Cheyenne Super
thanks for the part numbers guys i'll go bug my napa man tomorrow, i love to see his face when i come in, he knows it's gonna be work.
3B Offline
Hy panman, I've done the Napa crossovers for you,so you can walk in with the numbers and shock the heck out of him!
Raybestos H9206 = Napa p/n UP2474
Raybestos H7019 = Napa p/n UP2987
Raybestos H1508 = Napa p/n UP80561
Raybestos H1500-2 = Napa p/n UP80562
I hope that helps you blow his mind!
Moderated by  Dusty53
