1 members (papas52),
111
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,105 Posts1,056,542 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 4 New Guy | | New Guy Joined: Mar 2009 Posts: 4 | Hi just got new headlight rims and clips with seal without any paper work truck didn't have any on it when I got it does anyone know how the seal and clips fit on the rim pics would be good thank jim | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Here is a pic for 47 to 54 from classic parts ...click... | | | | | Joined: Mar 2009 Posts: 4 New Guy | | New Guy Joined: Mar 2009 Posts: 4 | thank pic helped had clips in wrong thanks again jim | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The only problem with the new headlight buckets,seals and rims is they were built by the Chicoms and are very hard to fit. I still have one rim that I can't get the screw to work. I guess I'll have to ream out a new hole or go back and use the originals.
~Jim
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I used new clips and rings on mine and ended up rebending the clips until they would work ,compare them to the old ones and you will see the differance.
Pete | | |
