8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, msmall), 122 guests, and 4 robots.
Topics128,065
Posts1,055,863
Members48,428
I'm hoping either this winter or next year to pull the motor out of the '37 and rebuild it. The motor, I've been told, is a 1947 235.
When looking for motor mounts, do I get ones for a '37 truck, or a '47 motor? (I'm guessing the motor, but thought I'd better double check.)
Thanks!
You will have to look and see what was used.
1951 1 Ton Completed
After engine is pulled, right? Or can I tell before-hand?
1932-54 truck used the same front mount
My Blog
Thanks! That helps. smile
