8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, msmall),
122
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 69 | Does anyone know where I can get a new center driveshaft bearing for my '49 1-ton? Thanks.
ron | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy uncleb, the bearing is Bower p/n 88107, hope that helps. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | Or O'Reilly Auto parts part number 88107 or BR88107 with most any Other supplier. Mike | | | | | Joined: Jul 2007 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 59 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | I see you guys linking the bearing itself - has anyone ever come across the rubber carrier itself?
Mine has play in the mount, not sure if that warrants replacement or not. | | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | Try Auto value, In Calgary My Canadian 1955 1430 1 ton dump needed a new cushion. They had both type of bearing supports c/w bearing in stock. One looks like a pillow block the other is like a upside down P. I do not have the part # with me today but could get it for you. Your 49 may use a similar part.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Thanks Howies - if you could find a part number, that would be awesome!
