| | | Forums66 Topics128,187 Posts1,057,212 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 42 New Guy | | New Guy Joined: Oct 2010 Posts: 42 | Newbie here. So while doing some bodywork with Evercoat Rage Gold I inadvertently dropped some on the driveway, stepped in it, and continued to make my way around the fender I was working on. As you can guess, bright green body filler tracks across my driveway. Driveway is asphalt, unsealed, so tons of nooks and crannies that the body filler filled. Any ideas how to remove it? Thanks. Newbie 1950 Chevy 3100 | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Paint it. You'll never remove it without removing the asphalt unless you were lucky enough for it to drop on top of oil stains.
| | | | | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | Heat it up with a Propane torch, and scrub it with a steel-bristle brush. Above about 400 degrees F., the Bondo decomposes. That's also the easy way to remove it from sheet metal- - - -heat the back side of the panel a little, and whole chunks of it will peel off with a putty knife. Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The techniques posted above sound good. If they do not work, rent a soda blaster and give that a try?
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Heat it up with a Propane torch, and scrub it with a steel-bristle brush. Above about 400 degrees F., the Bondo decomposes. Asphalt binder melts at 250.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | get creative, slop some more around, green is in ya know  | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | It is on some folks teeth anyway.
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I would use a belt or orbital sander with 60 grit paper keeping it flat and then wipe down with some acetone. That should clean up most of the filler. The acetone should blacken the rest of the filler in the cracks and time will do the rest. | | | | | Joined: Jul 2011 Posts: 10 New Guy | | New Guy Joined: Jul 2011 Posts: 10 | i would just give it time. it will wear off before the ashpalt will | | |
