5 members (Gray_Ghost, Maybellene, Gdads51, TUTS 59, Hanks custodian), 77 guests, and 3 robots.
Topics128,066
Posts1,055,871
Members48,428
#780834 09/15/2011 12:04 AM
U
U Offline
Does anyone know where I can get a new center driveshaft bearing for my '49 1-ton? Thanks.
ron
uncleb #780980 09/15/2011 3:42 PM
3B Offline
Hy uncleb, the bearing is Bower p/n 88107, hope that helps.
3B #781119 09/16/2011 1:00 AM
OLTrucks
Unregistered
OLTrucks
Unregistered
Or O'Reilly Auto parts part number 88107 or BR88107 with most any Other supplier.
Mike
#781160 09/16/2011 3:20 AM
NAPA offers them.
Joe
1947 Second Series GMC 1-Ton Longbed
More pix in the Bolt Bucket
GMCJoe #781172 09/16/2011 3:39 AM
I see you guys linking the bearing itself - has anyone ever come across the rubber carrier itself?
Mine has play in the mount, not sure if that warrants replacement or not.
Bigtonka #782969 09/23/2011 1:29 AM
Try Auto value, In Calgary My Canadian 1955 1430 1 ton dump needed a new cushion. They had both type of bearing supports c/w bearing in stock. One looks like a pillow block the other is like a upside down P.
I do not have the part # with me today but could get it for you.
Your 49 may use a similar part.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
Thanks Howies - if you could find a part number, that would be awesome!
Moderated by  Dusty53
