6 members (FAST55, Eric P Jr, Alex52, Frank50, Goach2, Hotrod Lincoln), 93 guests, and 3 robots.
Topics128,188
Posts1,057,220
Members48,465
Newbie here. So while doing some bodywork with Evercoat Rage Gold I inadvertently dropped some on the driveway, stepped in it, and continued to make my way around the fender I was working on. As you can guess, bright green body filler tracks across my driveway. Driveway is asphalt, unsealed, so tons of nooks and crannies that the body filler filled. Any ideas how to remove it?
Thanks.
Newbie
1950 Chevy 3100
Ex Hall Monitor
Ex Hall Monitor
Paint it. You'll never remove it without removing the asphalt unless you were lucky enough for it to drop on top of oil stains.
H Online: Content
Heat it up with a Propane torch, and scrub it with a steel-bristle brush. Above about 400 degrees F., the Bondo decomposes. That's also the easy way to remove it from sheet metal- - - -heat the back side of the panel a little, and whole chunks of it will peel off with a putty knife.
The techniques posted above sound good. If they do not work, rent a soda blaster and give that a try?
Ex Hall Monitor
Ex Hall Monitor
Asphalt binder melts at 250.
get creative, slop some more around, green is in ya know wink
Ex Hall Monitor
Ex Hall Monitor
It is on some folks teeth anyway. grin
I would use a belt or orbital sander with 60 grit paper keeping it flat and then wipe down with some acetone. That should clean up most of the filler. The acetone should blacken the rest of the filler in the cracks and time will do the rest.
i would just give it time. it will wear off before the ashpalt will
