6 members (SmalltownTRKGuy, Otto Skorzeny, moparguy, Gdads51, dt235sd, 1 invisible), 76 guests, and 4 robots.
Topics128,094
Posts1,056,056
Members48,433
#780141 09/12/2011 4:21 PM
Can main caps be machined to fit a different block? Trying to decide if worth keeping or just toss a set. Never know when a Stovebolter might need a set or a single cap. Should add that these are from a '55 235.
Drew
DrewP #780153 09/12/2011 5:06 PM
The process is called LINE BORRING. They place the caps and torque them down. Then they run a mic to check how far out they might be. If with in the line bore spec, they bore them to engine tollerance.
pearlhr41 #783483 09/25/2011 4:41 AM
1 Offline
Drew,
I even "Narrow" rods for other applications. I have on occasion also widened the space between the crank throws and have a CNC Machine Shop in Roseville do that type of precision work for me.
Normbc9
