3 members (tclederman, UtahYork, 1 invisible), 105 guests, and 2 robots.
Topics128,031
Posts1,055,433
Members48,422
#779982 09/12/2011 2:36 AM
V
V Offline
I was working on the lights and ran into a question I cannot answer. Do the parking lights stay on in the front in both headlight switch positions? On Jessica's truck the rears stay on, but the fronts go out when the headlight switch is pulled out completely (headlight position), but they will stay on in the mid (parking light position) Is this how the switch should function or do I need a new switch?
Thanks in advance for your time.
Jessica's Truck
The true definition of insanity:
To do the same thing the same way repeatedly and expect a different result each time.
The switch is funtioning properly, the parking lights are supposed to only be on in the mid position, and off when the headlamps are on.
Bill Burmeister
V
V Offline
Long Box,
Thanks for the quick reply.Looks like I will be replacing the switch any way.While playing with it I realized sometimes the taillights would not come on till I jiggled the switch and for $14 I guess it worth it.
Jessica's Truck
VI - if you want the park lights to be 'always on' [running lights], it's a simple wire addition, here, from tech tips
V
V Offline
Squeeze,
Thanks for the tip . Once I get the new switch I will add the jumper to make the lights stay on with the headlights. Additionally I swapped the single element lamp holders in front for dual element (1157) so the turn-signals will work there as well.
Jessica's Truck
huh, that's a suprise, I thought by 59 they all had the dual element sockets even if they didn't come with factory signals
V
V Offline
Jessica's '59 has the aftermarket switch on the column and holes in the tops of the front fenders where the signals were located. The parking lights which I assume were from this truck were only single element lamps with single pin sockets. I guess the lights could have been from an older donor, but I am not sure.
Jessica's Truck
Hmm... strange. My 1958 has the two wire pigtail already in the front parking light with the 1157 bulb. Only one wire was used for the parking lamp, but could easily add turn signals to it.
This is interesting. My '59 Apache panel had factory turn signals, and I always thought they were standard after '57 or so....! Maybe not?
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
signals didn't become standard until in the 60's, they were an available option after 54
They became an option with the '54 models. They were available as an accessory before that and used separate lamps. I too thought anything '54 and after would have dual sockets but my '59 GMC Fleet option doesn't.
