1 members (Woodcmiami),
72
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | I was working on the lights and ran into a question I cannot answer. Do the parking lights stay on in the front in both headlight switch positions? On Jessica's truck the rears stay on, but the fronts go out when the headlight switch is pulled out completely (headlight position), but they will stay on in the mid (parking light position) Is this how the switch should function or do I need a new switch?
Thanks in advance for your time. Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The switch is funtioning properly, the parking lights are supposed to only be on in the mid position, and off when the headlamps are on.
Bill Burmeister | | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | Long Box, Thanks for the quick reply.Looks like I will be replacing the switch any way.While playing with it I realized sometimes the taillights would not come on till I jiggled the switch and for $14 I guess it worth it. Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | VI - if you want the park lights to be 'always on' [running lights], it's a simple wire addition, here, from tech tipsBill | | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | Squeeze, Thanks for the tip . Once I get the new switch I will add the jumper to make the lights stay on with the headlights. Additionally I swapped the single element lamp holders in front for dual element (1157) so the turn-signals will work there as well. Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | huh, that's a suprise, I thought by 59 they all had the dual element sockets even if they didn't come with factory signals
Bill | | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | Jessica's '59 has the aftermarket switch on the column and holes in the tops of the front fenders where the signals were located. The parking lights which I assume were from this truck were only single element lamps with single pin sockets. I guess the lights could have been from an older donor, but I am not sure. Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Hmm... strange. My 1958 has the two wire pigtail already in the front parking light with the 1157 bulb. Only one wire was used for the parking lamp, but could easily add turn signals to it. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | This is interesting. My '59 Apache panel had factory turn signals, and I always thought they were standard after '57 or so....! Maybe not?
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | signals didn't become standard until in the 60's, they were an available option after 54
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | They became an option with the '54 models. They were available as an accessory before that and used separate lamps. I too thought anything '54 and after would have dual sockets but my '59 GMC Fleet option doesn't. | | |
