| | | Forums66 Topics128,060 Posts1,055,835 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 62 | Hey all. I bought a rebuilt 216 a few months ago that had been sitting unused for close to 10 years since its rebuild.
I popped the oil pan off to give it a once over and one thing that I've noticed is there is very little crankshaft endplay.
How tight/stiff is the crank supposed to be? I should be getting a small but measurable amount of wiggle, right? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Unless it had a major failure I think you are probably looking at the buildup of something that will not affect the running of it. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | End play should be .003-.009" (SEE MANUAL), but I have seen them run fine with a lot more.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2008 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 62 | Unless it had a major failure I think you are probably looking at the buildup of something that will not affect the running of it. End play should be .003-.009" (SEE MANUAL), but I have seen them run fine with a lot more. Thanks for the info guys! | | |
