6 members (Ridgeback, rick46ia, Otto Skorzeny, klhansen, MNSmith, 1 invisible), 109 guests, and 4 robots.
Topics128,022
Posts1,055,373
Members48,420
#748666 05/21/2011 5:00 AM
Has any anybody installed a class 2 hitch on there 55/59 second series. I need to find one for my 55 GMC 1/2 ton and havent had any luck. Is the frame the same as the early 60 models that might be eaiser to find. Thanks for your help
Fred
Freds55 #748677 05/21/2011 5:53 AM
My '56 Chevy 1/2-ton has a Reese receiver hitch, part # 06082. The holes had to be elongated a touch to mount it.
Cletis #748689 05/21/2011 7:15 AM
Yes, the frame is 34 inches... should be the same from roughly 1955-1998. Look on your local craigslist, and if possible dry fit the hitch by holding it in place before buying it.
There are a few other considerations for hitches. Some might have more or less drop than others.
I got the hitch for my 59 off craigslist. I believed it is a drawtite hitch, but the number isn't legible. When I got it, it fit perfectly under the barden bumper. My 59 is a longbed, and the hitch would often bottom out on steep driveways, so I recently removed and modified the hitch to go through the bumper.
This is a DrawTite #75034
http://img.photobucket.com/albums/v228/Avette4me/My%2058/Brakes/Backuplights.jpg
Some, but not too much modification required and the spare fits.
Avette4me #748833 05/22/2011 12:34 AM
Thanks for the info guys. This gives me a place to start, I dont know what i would do without this site.
Fred
Freds55 #779073 09/08/2011 11:34 AM
Avette4me,
Did you have to modify your bumper to install the hitch? It's hard to tell from the picture.
What type of modifications did you have to do?
Steve
smaiocco #779132 09/08/2011 5:19 PM
I installed a Curt 13028 Class III I got for 45 bucks on Ebay. Was new. The fellow just never installed it. Here is my video of the install if you want to see it.
Here is the 2 inch ball installed. It is 19 inches off the ground. Works out great.
http://talk.classicparts.com/picture.php?albumid=180&pictureid=1717
A small photo. Not sure why. Was bigger
smaiocco #779610 09/10/2011 1:58 PM
Originally Posted by smaiocco
Avette4me,
Steve
No modification to the bumper was required.
I had to tweek the spare holder and cut an extra hole in the hitch. No big deal at all.
Avette4me #779791 09/11/2011 12:19 PM
Thank you both for the info.
Steve
smaiocco #779795 09/11/2011 1:17 PM
Ex Hall Monitor
Ex Hall Monitor
Why are you wanting a class II hitch? It severely restricts what you can haul. A class III would be much more capable for general hauling.
Tiny #779859 09/11/2011 6:21 PM
Hi Tiny,
Good question. I was actually thinking about a Class III. It seems that the Drawtite 75034 is available as a Class III or a Class IV hitch.
Steve
smaiocco #779890 09/11/2011 9:33 PM
Ex Hall Monitor
Ex Hall Monitor
I think you'll be happier with a class III.
Tiny #779953 09/12/2011 1:38 AM
I agree. There around the same price if only a little more and you can tow so much more.
I built my own. The only part that was not fabricated was the receiver, for $12 it was cheaper to buy the Reese one already made up. But the rest was custom fabricated, patterned from the Class 3 hitch from my Dad's '88 K2500. We did make a few changes, the side plates are heavier, and the drawbar is 4" instead of 3".
Bill Burmeister
