9 members (2-Ton, DadsFirstPickup, 32Fordpuchoptop, FAST55, Otto Skorzeny, mason86, rfs56trk, TexasJim50, Forty9),
102
Mod | | | Forums66 Topics128,049 Posts1,055,661 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | 1953 3600 series. Not sure if this belongs here or in Electrical. PO had brazed a metal piece to the stoplight switch arm. Obviously was having as problem in the arm being too far away from the pedal.
Switch failed, and I got a new one. Installed it in the same holes, as shown in the Factory Assy Manual Sec 12 Sheet 4.05 Part 3707902. Must say that the manual seems to shoiw the switch arm pointing left, tpoward the driver's side, rather than right. But can't see how to change that.
Anyway used same switch as PO (NAPA SL128). But the the actuating arm is nowhere near the pedal and would never work properly. I adjust the pedal closer to the firewall by using the master cylinder adjusting nut, but that would never be enough, either.
Whassup? Anyone know?
Thanks, Harry
Last edited by Woogeroo; 09/11/2011 9:56 AM. Reason: added year/model to subject to attract knowledgeable people
| | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | Hi Harry, Here is information from my 55 first series truck. Hope it is relevant to you. The stop light switch points to the right or passenger side. My truck also has a very specific embossed section the brake switch mounts to. This page is from the 54 shop manual. It shows the brake switch pointing also to the right or passenger side of truck. http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm1238.html If you have the 53 manual it may have a similar diagram. Great job identifying the issue and posting relevant pages in the FAM. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Here ya go Harry, this is a ‘50, 3600 but it should be the same as the ‘53. The new switch in the second picture is the one that all of the vendors carry from Counterpart. Don’t see why you would be having a problem if you have the correct switch, it’s a simple two screw install. http://www.pbase.com/dennygraham/image/137963486/large http://www.pbase.com/dennygraham/image/137963488/large I avoid buying parts from my FLAPS because most of the time the kid behind the counter has no idea what he’s looking for and they really do not have much that will fit these old truck. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Harry -
Make sure that both mounting screws are tight. If one of the holes is enlarged, it may allow the switch to move out of position. The previous owner may have tried to compensate by using the switch you described.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You probably have the wrong switch. Some applications use a switch with the lever on the opposite side. Often the parts stores get them boxed wrong even if the part number on the box is correct. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | Thanks to all of you. Now I will send the pix I should have taken in the first place. Here they are: http://share.shutterfly.com/share/r...80031ecd658bfd733&sid=8AZOGLNu0bMmRPI think I have the correct switch, and I did mount it correctly. I tried an ohmmeter, and the lever arm has to be almost level before it cuts off. So, I looked for the obvious - maybe the pedal is too far from the firewall. I redid the master cylinder adjustment to bring it closer, but then the bottom end bangs on the steel flange beteen toe plate and firewall, especially when I remove the bumper. Even with max adjustment at the threaded turnbuckle, I could not get the switch to cut off. Once again, thanks for your help. Maybe the pix raise some thoughts? | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | There is no bumper on the brake, only the clutch. On mine the master cylinder turnbuckle is threaded onto the shaft all the way to were the shaft is flush with the bottom of the U in the turnbuckle. Is your return spring for the brake pedal hooked up? FAM sect 5, sheet 2.00 shows how to adjust the clearance of the brake pedal.
Ed
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can put a piece of vacuum/fuel hose over the lever on the switch. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ed's got it Harry, there isn't a rubber bumper on the brake lever just the clutch, that's whats holding it from coming back far enough to trip the switch. Did you look at this picture: http://www.pbase.com/dennygraham/image/137963486/large Simple fix, cut that rubber sucker off! DG
| | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | Problem solved. Very strange, but the reason is actually visible in the one picture I posted that shows the rubber bumper. That's where the problem was, but it wasn't the bumper itself. Look at the picture again, and notice what the bumper is bumping against! Where there should be a smooth joint between the firewall and toe panel, mine has a 1/2 flange sticking out, for about 6 - 8 inches laterally. Both the brake AND clutch pedals were hitting that flange before they ever got close to bottoming out. The PO probably placed the rubber bumber there to prevent metal-to-metal clanging. Because the pedal was hitting the flange way down low, there way no way it could ever actuate the stoplight swith. So, I used boltcutters, hacksaw, vise grips, and a wrecking bar to cut and/or bend the flange. When it was gone, I adjusted the brake cylinder clevis as suggested, reinstalled the switch, and everything works great! Thanks again to all of you for getting my brain cells working again. | | |
