| | | Forums66 Topics128,281 Posts1,058,479 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | I'm having a hard time getting the raybestos part numbers for the front and rear wheel cylinders on my 59 3800, the parts books at the local flaps only go back to the early 60s I can get them at a fair price if i can just get a p/n I need them for the front and rear shoes too if anybodys got that info. Thanks everybody | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy panman, the Raybestos numbers are front wheel cylinders WC18009 rear wheel cylinders WC18010 front brake shoes 123PG rear brake shoes 109PG hope that helps. | | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | thanks 3B that's a good start, i hope i can find that stuff . | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy panman, Rock Auto has all the parts, prices are in Canadian dollars (forgot to select U.S. dollars, so prices will be a bit more) 123PG $23.71 109PG $70.53 WC18009 $20.92 WC18010 $45.73 hope that helps. | | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | hey 3b i got my shoes from Napa today, they had them on the shelf! i couldn't believe that, i ordered the rear wheel cylinders from Kanter in new jersey, they had them oem, on the shelf too $40.00, What i'm having real trouble with now is some kind of spring set, and getting the shoe adjusters unstuck. I think i can get the one adjuster that is still stuck apart, but i would really like to get some new springs, 3B do you have the part number for a spring kit?? and new adjusters? man that would be kool but man i really want to thank you for those part numbers it helped me a bunch | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy Panman, this info was a little tricky to find, and I can't be 100% sure of it, I think the rear spring kit should be Raybestos p/n H9206, I think the front spring kit should be Raybestos p/n H7019, I'll keep looking for the adjuster assemblies. Do you need both front and rear adjusters? | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy panman, rear adjusters are Raybestos p/n H1508, front adjusters are Raybestos p/n H1500-2, you could use p/n H1500 as well, I don't see a difference in the pic's but H1500-2 is cheaper???, hope that helps, I've got a headache now, so off the confusilator for me. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | the napa part # on the springs for 12 in. brakes are 80301 for the return springs. 80412 for the hold down kit. That is axle sets & the same for front & rear.The adj. screw spring is 80518. It doesnt show the adj. screw. Usually some heat will free it up. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | thanks for the part numbers guys i'll go bug my napa man tomorrow, i love to see his face when i come in, he knows it's gonna be work. | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy panman, I've done the Napa crossovers for you,so you can walk in with the numbers and shock the heck out of him! Raybestos H9206 = Napa p/n UP2474 Raybestos H7019 = Napa p/n UP2987 Raybestos H1508 = Napa p/n UP80561 Raybestos H1500-2 = Napa p/n UP80562 I hope that helps you blow his mind!
