| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 32 | Someone Cut with a hacksaw our parking brake cable near the front, so we can't hook up the brake to the handle. I was wondering if there is anything that would work to fix that, I would be ok with something new from the parts store if it would work. We need the brake to function so it will pass inspection and be safe. Not sure what we could find that would work maybe compare wheel base's with a newer truck and see if we could make something happen.
Also, I can't get any Pedal in the brakes. I installed new lines in the rear, and Was attempting to bleed them but I cant get any pedal/pressure to build up. Is this a sign that the wheel cylinders and or the master cylinder is bad?
If so is it worth time to attempt a rebuild on the wheel cylinders or the master cylinder or just replace with new one's from Carter's? | | | | | Joined: Aug 2011 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 32 | hmmm, No advice from anyone. Im at a loss as to what the next step should be. | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Lovethetruck
After trying to fix my brake system I with the old parts they still leaked... So I went ahead and replaced the whole system... With all new parts I did go with DOT 5 fluid... I used Speed Bleeders on the wheel cylinders so I could bleed them with no assistance... I also replaced the parking brake cables...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | 1) The parking brake cable. I'm assuming this the bar that extends from beneath the floorpan to the rear crossbar? If you have both pieces and you can remove them, see if a weld shop can safely weld it together or fab a new one for ya. Sorry no replacements for that available unless you find it off another truck.
2) Cylinders. You should check for leaks around the wheel cylinders and master. You just put in new lines, and you might as well put in fresh parts for trustworthy brakes.
P.S. Some of us don't check the CrashBoxShop (generally transmission stuff) all too often. You could ask a brake question in General Truck Talk.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
