5 members (Gdads51, Otto Skorzeny, MickeyP, dt235sd, JW51), 62 guests, and 1 robot.
Topics128,049
Posts1,055,698
#779656 09/10/2011 7:49 PM
Hi All,
I just installed new window channel rubber and the inner and outer 'wipers' in the door of my 68. Now the window is exceptionally hard to roll up and down. I did not know how to get to everything in the door so at one point I had the regulator completely unbolted. There was a bang when the last bolt came out. Now I'm wondering if the spring somehow came off the regulator. I never did figure out how to get the window glass and regulator completely out of the door so I haven't been able to do a visual inspection. If anyone has any ideas on this I would greatly appreciate it.
40 chevy 1.5 ton, 50 chevy 3/4 ton, 67 chevy stepside 1/2 ton, 67 C50, 68 C50, 73 chevy 4x4 3/4 ton, 2004 Silverado 1/2 ton , 2005 HD 3/4 4x4 Duramax (don't even get me started about my Oldsmobiles!)
It's not the same, but similar till someone else comes along you might try here
59 Chev resto page
I think there is a removal procedure in it.
Give me ambiguity
or give me something else
It turned out to be worn-out/sprung window regulators. Put in new ones from LMC at 39.00 each and they go up and down easier than I thought possible. Now nice and tight, no rattles and easy up - easy down!
One last note on this, the October 2011 issue of Custom Classic Trucks magazine has an article on replacing door weatherstrip/rubber in the 67 to 72 Chevys. At some point I believe they will publish the article on line.
I hope someone finds this helpful.
