Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Sjm, Ponchogl, Dakota Bob, Wally / Montana), 89 guests, and 5 robots.
Topics128,275
Posts1,058,439
Members48,490
#77962 05/24/2007 1:21 AM
Two questions,....49 1/2 ton w/sm420 I think. I have unbolted the back tranny plate and threaded the coller off the bellhousing...enclosed driveshaft by the way. The bellhousing on the rear of the tranny covering the u-joint won't come loose. Is it supposed to just slide back or what? Next question....the front crossmember on the drivers side has about 3" of rusted out area. Can this be repaired without replacement of the cross member? My Dad gave me this truck and it would really be a setback to have a bad frame. I dont post much but try to read alot! Thanks in advance Rick
JJs49er,
1. The bellhousing on the rear of the tranny covering the u-joint won't come loose. Is it supposed to just slide back or what?
The outer surface of the torque-tube, behind the collar, has to be completely/shiney clean in order for the collar and "bell" to slide backwards.
2. The front crossmember on the drivers side has about 3" of rusted out area. Can this be repaired without replacement of the cross member?
It is hard to answer this question without seeing the damage (is this the cross member under the radiator?). It might be repairable by a skilled welder, depending on the extent of the rust-out. Most likely you will need a different frame or crossmember - a frame should be fairly easy to find.
Tim
#77964 05/24/2007 12:38 PM
U
U Offline
To move the universal ball back, give the retainer a tap towards the rear with a screwdriver and hammer.
It should then move. Worked for me.
unbroke
Can U believe it? My wife says: "I want an old pickup truck" so I HAD to buy it!!
'50 Chevy 3100 5 window.
tcl...yes its the radiator support and front engine mount. This I would have done by a skilled welder, I hope for the best there. The bellhousing, I will try those ideas. Thanks Rick
unbroke did you leave the collar attacked when you tapped it back? I took it loose and slid it back seperate.
got the bellhousing off today. I put the collar back on,cleaned the saft good and tapped back as told. That worked.
oops...no such thing as a saft smile > but the cold ones sure tast good tonight!
U
U Offline
Glad you figured it out.
Cold ones tast gud al da tyme...
unbroke
