| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 37 | I have a push start 261 in my 57 3100. I want to convert it to a key start. Do I need to buy a new starter, or will adding a solenoid to the old starter do the trick? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Ralf, I'm afraid it's new starter time, the stomp starter cannot be converted to a solenoid type. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Can't add a solenoid to your old one. Parts store should be able to get you one with a solenoid.
I like my stomp starter. | | | | | Joined: Sep 2009 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 37 | | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Tractor supply sells stomp starter switches. You can use one of these and use it in conjunction with a solenoid type starter. | | |
