| | | Forums66 Topics128,094 Posts1,056,483 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I was picking up some 64-66 truck doors tonight and there was this model 1433 sitting there . flatdeck. looked like the gvw was 8000lbs didn't deem like a very long w/b. 47-54 variety ron | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Canadian 1T [=US 3800], cab&chassis model I believe, 135" WB
Bill | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think the wb is 137". My 1951 1 Ton says "9430" on the hood and the literature calls it a 9434. My GVW is 5700 lbs. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | My 1 Ton is a 1434 if I recall. 137" wheel base, and the GVW is 6700 lbs. The farmer that bought mine, must have sprung for heavier tires than Truckernix's!
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | As silly as it is, I believe that is probably why my GVW is so low! | | |
