3 members (Nick in Manitou, Hotrod Lincoln, Shaffer's1950), 119 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
#775871 08/28/2011 10:51 PM
Picked up a sweet old pulpwood truck a few weeks ago original owner 54000. miles 3 flat dry rotted lock ring tires. Tubeless is what im thinking posted this question in 60-66 forum them saw tons o fun what will fit ? Thanks !
Hello,I have a 66 c30 that had the lock ring wheels. They were in bad shape(rusted,bent)so replaced them with 16"rims from an early 80's 1 ton No problems fit just fine. I did drill the hubs and replace the 1\2 studs with 9/16 but the lugs will still stay tight if you don't. Also I run 215/85/R16 radials on it Hope this helps.....Mike
Thanks currently seeking a mid 80's dually .
your wanting the bud wheels , i found myself a 1967 c/30 online im seeing about geting
Moderated by  Dusty53
