4 members (68ironhead, Hanks custodian, Gray_Ghost, Ponchogl), 51 guests, and 3 robots.
Topics128,026
Posts1,055,404
Members48,422
#776857 08/31/2011 10:14 PM
I sripped a stud on a big bolt dayton wheel hub.(1 of the 5 there) How do you get those studs out for replacement? Mert
gto57 #776891 09/01/2011 12:07 AM
I don't know if your Dayton wheels have press-in or thread-in studs.
This may sound too obvious, but press-in studs will press out. You just need a suitable support to avoid distortion of the hub and a big enough press. Don't expect them to move for a love tap from a tiny tack hammer.
If they are thread-in, you might get a stud extractor/installer to do the job after a repeated soaking with penetrating oil but you might have to resort to more forceful methods. If kindness doesn't work, heat may help. One way is to get a nut that is meant for the stud (can have threads in poor condition or stripped) thread or shove it a bit less than half the depth of the nut onto the stud and weld it solidly in place filling the hole in the nut as you work out. Once it has lost the cheerful red colour but before it is fully cooled apply some more of your favorite penetrating oil at the wheel/stud joint that will at least partly go up in stinking smoke, place your socket and impact gun that you thoughtfully placed near by before welding onto the newly made hex on the stud and have at it. Many very stubborn studs and sheared bolts have come loose with this method. It works better on short studs as the heat cycle has less distance to travel to free the rust. Applying heat to the parent metal the stud is threaded into by another way should have the same effect but for a big lump of steel you will also need a big torch. Sorry if it seems I'm stating the obvious here.
Grant_Bowker #776902 09/01/2011 12:27 AM
3B Online: Content
3 Online: Content
Hy gto57, could you tell us what year and size of truck you're asking about, that way we can give you the facts on stud removal, rather than guessing.
Grant_Bowker #776904 09/01/2011 12:29 AM
Thanks. Your response is much appreciated. Mert
3B #777180 09/01/2011 11:54 PM
Hi. The truck is a 1965 c-80 chevy. Thanks. Mert
gto57 #777225 09/02/2011 1:01 AM
3B Online: Content
3 Online: Content
Hy gto57, according to my Canadian parts book that stud should be threaded on each end, 5/8" x 11 x 2 3/4" GM p/n 2162150, Napa p/n TWD WA1281 $1.29 each at the store I checked, hope that helps.
3B #777296 09/02/2011 4:03 AM
Thanks. Mert
3B #777675 09/03/2011 1:02 PM
I did find your PN at our local NAPA. Turns out though that my studs are 3/4 inch. Do you happen to show a listing for that on a 65 chev c-80 with daytons? Mert
gto57 #777680 09/03/2011 1:17 PM
At this point pull one out and compare at NAPA they are pretty comon/standard.
Early on they used 5/8" studs and later transitioned to 3/4" dayton studs.
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #777685 09/03/2011 1:41 PM
Thanks much. Mert
gto57 #777736 09/03/2011 4:10 PM
3B Online: Content
3 Online: Content
Hy gto57, the GM p/n for a 3/4" stud with almost the same dimensions as the 5/8 stud I already gave you the p/n for is 2066639, I can't get the Napa site to come up this morning, but maybe the guys at Napa can cross that number for you, hope that helps.
gto57 #777737 09/03/2011 4:11 PM
3B Online: Content
3 Online: Content
3B #777831 09/03/2011 9:14 PM
3B Online: Content
3 Online: Content
Hy gto57, I finally got the Napa site to wake up, their number for stud p/n 2066639 is TWD WA1282, hope that helps.
