0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 36 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 36 | I installed rebuild kits on 1950 chevy 1/2 ton brake cyl. and master cyl. Used old cap on mc and air and fuild ooze out of tiny hole in the top of cap. Any help would be appeciated. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't know what stage you are at but if you have it too full, it coukd be a problem. Also the MC linkage should be adjusted as per the manual. | | | | | Joined: Aug 2011 Posts: 36 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 36 | I'll try taking some fuild out,still confused on reason for a hole in the top of the cap.Wouldn't it let air in? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes it lets air in, to allow fluid movement in and out of the MC - the level should be slightly below what the inside of the cap would touch, not filled to the rim - also, you may find the system hasn't had the air fully bled out and that air is pushing back against the fluid in the MC .... the exposure to ambient air is the drawback of the old simple systems, the fluid will slowly absorb moisture, so should be flushed and changed occasionally
Bill | | | | | Joined: Aug 2011 Posts: 36 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 36 | Thanks Bill, I'll give it a try | | | | | Joined: Sep 2011 Posts: 39 New Guy | | New Guy Joined: Sep 2011 Posts: 39 | I am going to rebuild my brake system and would like to flush the brake lines. What should I use to do the flush? Do I just run brake fluid through the lines, or is there a brake system cleaner? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can flush them with alcohol but time you bleed them you will get all the old fluid out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
