0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | The engine is together, carb and all, and is ready to be dropped in to my 1946 Stylemaster. I needed to replace my motor mounts. I stripped both bolts (they were frozen) and proceeded to cut them off. Now I find myself looking for a set of fine thread hex bolts to use and guess what? Nobody has them.... Autzone, Lowes, Tractor Supply, and Napa... none of them carry these bolts. I need them ASAP; this engine has to be in and running by this Thursday!
Any ideas?
Dan
1946 Chevy Stylemaster Sedan - 216 6 Cylinder 1971 Chevelle SS 1995 Monte Carlo Z34 2005 Corvette Z51
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Use coarse thread bolts until you can get the right ones. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I had trouble finding those too. I used coarse thread and double nutted them, not sure if that is recommended or not, but it works for me. | | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 |
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I don't know if there are Grainger or Fastenal stores in your area but Grainger carries fine threaded bolts from 1/4 to 3/4 diameter and Fastenal has them in an even broader range.
Evan
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Try McMaster Carr. If they do not have them you do not need them. http://www.mcmaster.com/#Harold
Harold Is a restoration ever finished? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Double nutting means putting the first nut on to where you want it and then using a second nut as a lock or jamb nut. I did the same thing. | | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | Well I went to Fastenal and they did not have it. Hit all the autoparts stores, no luck there. Then on my way home I was passing the 50 year old country hardware store... little hole in the wall in my town. Decided to stop just because I was out of options.....
You guessed it.... sitting right on the shelf.
DG
