5 members (UtahYork, Gray_Ghost, klhansen, mason86, Charles in CA), 95 guests, and 2 robots.
Topics128,069
Posts1,055,884
Members48,428
#776306 08/30/2011 12:45 AM
The engine is together, carb and all, and is ready to be dropped in to my 1946 Stylemaster. I needed to replace my motor mounts. I stripped both bolts (they were frozen) and proceeded to cut them off. Now I find myself looking for a set of fine thread hex bolts to use and guess what? Nobody has them.... Autzone, Lowes, Tractor Supply, and Napa... none of them carry these bolts. I need them ASAP; this engine has to be in and running by this Thursday!
Any ideas?
Dan
1946 Chevy Stylemaster Sedan - 216 6 Cylinder
1971 Chevelle SS
1995 Monte Carlo Z34
2005 Corvette Z51
Use coarse thread bolts until you can get the right ones.
Leo Offline
Moderator
Moderator
I had trouble finding those too. I used coarse thread and double nutted them, not sure if that is recommended or not, but it works for me.
Leo #776340 08/30/2011 1:58 AM
Double Nutted?
1971 Chevelle SS
2005 Corvette Z51
I don't know if there are Grainger or Fastenal stores in your area but Grainger carries fine threaded bolts from 1/4 to 3/4 diameter and Fastenal has them in an even broader range.
Evan
Try McMaster Carr. If they do not have them you do not need them.
http://www.mcmaster.com/#
Harold
Harold
Double nutting means putting the first nut on to where you want it and then using a second nut as a lock or jamb nut. I did the same thing.
1951 1 Ton Completed
Well I went to Fastenal and they did not have it. Hit all the autoparts stores, no luck there. Then on my way home I was passing the 50 year old country hardware store... little hole in the wall in my town. Decided to stop just because I was out of options.....
You guessed it.... sitting right on the shelf.
DG
1971 Chevelle SS
2005 Corvette Z51
