4 members (3800GUY, wilbur53, Jon G, Otto Skorzeny), 192 guests, and 0 robots.
Topics128,104
Posts1,056,201
Members48,436
My father accidently charged my 6 volt system with 12 volts for 5 hours or so.
The truck started fine before but does not want to start now. It turns over, has a spark but won't go.
What damage could 12 volts have done to my 6 volt system?
It's time to have a dedicated 6 volt charger for my truck to avoid this happening again.
Got it started after doing some checks. The 6 volt battery was sitting at 7.2 volts. Put some load on it just to bring it down to 6.25 volts and it fired up after a few tries. Everything seems to work fine, still haven't heard if the old man's charger faired as well.
Also removed the 6v/12v switch from my battery tender/charger.
I would check the fluid level in the battery.
1951 1 Ton Completed
The fluid level was low, thanks for pointing it out.
