1 members (2-Ton), 167 guests, and 3 robots.
Topics128,088
Posts1,056,114
Members48,434
#7755 02/17/2004 2:00 PM
Junior Member
Junior Member
I just got a nice set of kingpins and bushings for the front end of my '38 half-ton. The pins are supposed to be 0.7335 inches (can't measure that accurately with vernier calipers !) and the bushing are undersize. My question is: what's the proper clearance to establish between the pin and the bushing ? My guess would be 0.001 diametral clearance or less. I'm assuming I'll need to get there with an adjustable reamer, as none of my industrial catalogs list a reamer of the proper diameter.
Thanks !
Alex Meade
Lexington, KY
#7756 02/17/2004 3:58 PM
Bondo Artiste
Bondo Artiste
Hello! I had to have my Axle reamed out by a Professional Heavy duty truck shop. I don't know the clearance used but I do know it needs to be right or your will ruin your axle and or your new king pin set. I purchased the "oversixed" king pin set, even though I really didn't need them. Next time I will know better.
Look in your phone book under large truck repair. I betcha you will find someone who can fit it up for you and at a fair price. It will be worth it in the long run.......
~ Phillip
